Activity Forums Adobe After Effects Anime action background
  • Anime action background
    Posted by Justin Folk on July 19, 2005 at 2:26 am
    I want to create an anime/action style of background in After Effects. I want it to have the action lines/ect. to make it look as if something in the foreground is flying through the air… Any suggestions?
    -JR
    Satesh Ramjattan replied 21 years, 1 month ago 3 Members · 6 Replies
  • Chris Smith
    July 19, 2005 at 4:41 am
    Here’s a quick try at it using built in FX:
    https://sugarfilmproduction.com/animeBG.mov
    Here is the effect (apply to a solid). It’s a AE 6.0 FFX.
    https://sugarfilmproduction.com/Anime.ffx.sit
    Chris Smith
    https://www.sugarfilmproduction.com
  • Justin Folk
    July 19, 2005 at 7:10 pm
    Sorry if this is a dumb question, are you refering to an effect in AE called “built”? I understand the ffx file that you generously posted is a favorite, but for what effect?
  • Chris Smith
    July 19, 2005 at 8:04 pm
    I meant built in effects, as in not purchsed plug-ins.
    The FFX will put a Cell, Directional blur, median filter, and colorama with the appropriate settings placed onto a layer. Create a solid, add favorite and choose the ffx file.
    Don’t know if the keyframes carried over like they do in 6.5 though. If not, animate the vertical movement in the cell filter and the evolution a little bit.
    Chris Smith
  • Chris Smith
    July 19, 2005 at 8:07 pm
    I just tried it on a different comp in AE 6.5.
    For 6.5:
    Create a solid. Under the animation menu, select ‘apply animation preset’ and choose the ffx i gave you. All the effects and keyframes will appear on the solid. Just ram preview the first 2 seconds.
    Chris Smith
  • Justin Folk
    July 19, 2005 at 8:19 pm
    thanks so much. this is a lot of help…
    -JR
  • Satesh Ramjattan
    July 24, 2005 at 5:11 pm
    a real simple way using standard plugins is
    1. apply fractal noise to a solid
    2. using “transform” tab within FNoise, stretch out which ever way you please. turn off uniform scaling first.
    3 you can animate the direction and speed within the “sub-settings”, then adjust the “sub-offset” accordingly.
    4. almost done, apply colorama and choose whatever color goes with your action. I like the fire preset.
