Activity › Forums › Apple Final Cut Pro Legacy › Animatte in FCP???
Kevin Monahan
June 23, 2005 at 8:32 pmNot bad….except it makes a luma matte rather than an alpha matte. I find alpha mattes to be much cleaner.
Is it possible to re-assign the previous Timecode to the Motion Rendered Clip with the Modify>Timecode command? That might be easier and you’d get the alpha defined matte. I don’t have the hardware to run Motion, so I can’t check this.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com
