Activity › Forums › Adobe After Effects › Animation with leaves
  • Mike Park
    April 15, 2009 at 2:32 pm
    You can absolutely do this in AFX with Particular, if that is what you have. You will basically need to take your color layer, without the white background, make it a 3d layer in a comp. Next, create a new solid layer and apply particular. For an emitter choice, use either layer or layer grid, depending on the look you want. Create a new, small comp, say 200×200, and draw out a leaf shape. If you want to get more creaive and varied, you can make multiple leaves in this comp and use each randomly in particular. Back in your main comp, drag the small leaf comp in and turn its visibility off. Next, change particle type to cusom colorize or fill, depending on the look you want and choose the small leaf comp layer. Then, just play with either gravity, or wind to animate the leaves. Turning on a bit of turbulence and/or spin will help create a more random look. Play with the settings. This will have your logo blow away. If you want it to come together, simply time reverse the comp in another comp, or play with physics time in the negative.
    Hope this helps
  • First Last
    April 15, 2009 at 9:14 pm
    I like Mike’s idea, because it’d work and he’s able to explain how to do it.
    But, you might also want to look into the Foam effect. I think it’d work, but I do not know how to explain it.
    Same principal that’s in this tutorial. Has leaves, too.
    https://library.creativecow.net/articles/simpson_mark/growing_tree.php
    Production Associate
    Bend, Oregon, United States
  • Luis Konrad
    April 23, 2009 at 4:33 am
