Activity › Forums › Adobe After Effects › Animation using PSD layers – Weird export issues
  • Animation using PSD layers – Weird export issues
    Posted by Chris Warren on December 4, 2012 at 4:36 pm
    Hi all. I’ve been an unregistered lurker of CC for a while now, but need some help. I hope to be an active member of the community!
    I’ve had 4 years of AE experience but this is the first time for me animating using Photoshop vector shapes in AE. The whole animation previews fine in AE, but when it’s rendered (regardless of format), certain layers are invisible, and some are the wrong colour. I’ve attached a couple of images to explain the problem.
    Using Photoshop CS5 and After Effects CS5.5, both 64bit on Windows 7.
    How it should look ^ __________ How it looks when exported ^
    Thank you.
    *Edit: For clarification, there seems to be no difference between the shapes that are visible and the shapes that aren’t (the hair for instance is just a single vector shape in it’s own comp). All layers have been pre-comped. The phoneme shapes (there are more in the animation) are smart-objects, yet they display fine.
    Chris Warren replied 13 years, 9 months ago 3 Members · 4 Replies
  • Stefan Hinze
    December 4, 2012 at 9:06 pm
    hey,
    the hair is not set as a guid-layer?
    (take a step back, to see the bigger picture)
  • Chris Warren
    December 4, 2012 at 9:48 pm
    Nope, not guide-later. Not parented to anything else, no keyframes whatsoever on it, registration points are all proper…. baffling. The detail on the ears are invisible too. Just cant work out why certain elements are a completely different colour.
  • Michael Zoppo
    December 4, 2012 at 9:53 pm
    Chris, I’ve had this exact issue before. Everything would look fine in AE and then when I rendered I’d get certain elements with really low opacity with no reason at all why it happens. Go back and reload your footage or relink your footage/vector assets in the project panel and it should go away. I had to do the same thing to fix mine.
  • Chris Warren
    December 7, 2012 at 5:16 pm
    Thanks Michael! Even though I’m subscribed to this thread I didn’t get an email notification.
    I found that out when I came back to it the next day. Problem had disappeared. Odd little bug. Glad it wasn’t a compatibility problem.
    Thanks for your reply!
