Activity Forums Apple Final Cut Pro Legacy Animation to Final Cut Pro 4.5 help
  • Animation to Final Cut Pro 4.5 help
    Posted by 00roland00 on November 8, 2005 at 4:42 pm
    Hi, I’m producing an animated movie. Animation is created in Flash, exported via Quicktime (Animation codec renderer) and imported to Final Cut Pro 4.5.– In the beginning the film will be output to DVD, but someday might want to do a film transfer.– What’s the best frame size to work at… in Flash and then in Final Cut Pro? I prefer the 16:9 look as opposed to 4:3. —— I was thinking that since I may transfer to film, and film frame size is 1920 x 1080, I would do a proportionally smaller frame (800 x 450). But maybe I should just use a preset from Final Cut – like 720 x 480 and not worry about scaling up to film?
    Any suggestions?
    Bret Williams replied 20 years, 10 months ago 3 Members · 2 Replies
  • Chris Poisson
    November 8, 2005 at 5:32 pm
    Roland,
    Is your partner in this named Joel? I answered an almost identical post on Ken Stone a couple of days ago. Any FCPHD easy setup will work fine. Your choice.
  • Bret Williams
    November 8, 2005 at 6:46 pm
    720×480 IS 4×3. So you wouldn’t want that if you wanted 16×9 unless you were doing anamorphic.
