Activity Forums Adobe After Effects Animation sync to audio layer
  • Animation sync to audio layer
    Posted by Ron Bass on September 12, 2008 at 3:20 pm
    Need to animate the layer so that it syncs with a the announcer bed.
    Would like 4 to 5 rings that pulsate from the center in response to the audio file. Kind of like a subwoofer on a audio monitor.
    It can look basic. Simple rings that are scaled from smaller in the center to wider on the outer edge.
    Is there a quick tutorial on this method somewhere.
    Deadline looming…
    Thanks to anyone.
    Ron Bass replied 17 years, 9 months ago 3 Members · 4 Replies
  • Immanuel Morales
    September 12, 2008 at 8:18 pm
    best tut i’ve ever seen on this is on Kramer’s – VideoCopilot.net
    i’ve actually found this to be pretty tough if you want it JUST right and the beat isn’t distinct. it helps to have a very distinct kick and/or snare before you convert your audio to keyframes. if you don’t have that then you can try Andrew Kramer’s version which involves applying the bass & treble effect before converting to keyframes. this helps create that ideal situation. oh and using the “linear()” expression helps a ton too.. just open up the graph and check out the numbers so you know what values to put in for min and max threshold. i like to make sliders for the min and max and watch the values change in the graph
    Darqlight on the Rise…
  • Toby Rocke
    September 12, 2008 at 9:35 pm
    If you’ve got cash to splash, Trapcode Form has a preset that will do that exactly.
    “Outside of a dog, a book is man’s best friend. Inside of a dog, it’s too dark to read”
  • Ron Bass
    September 15, 2008 at 3:34 pm
    Thanks to both of you.
  • Ron Bass
    November 12, 2008 at 9:59 pm
    Thanks all.
