Activity Forums Adobe After Effects Animation – real hand footage – no green screen
  • Animation – real hand footage – no green screen
    Posted by Johannes Schwarz on November 20, 2012 at 9:34 pm
    Hi there,
    I’m trying to improve on my current method to combine an animation with
    real life footage for a project I’m working on.
    This is a test sample – pause to check out what the hand looks like at 0:26 for example:
    https://vimeo.com/50238330
    What I did:
    light green screen -> glass plate fixed 1 yard in front of green screen -> light hand -> take stills of my hand with a GH2 so I have 4k footage that I can shrink for better overall quality (and smoother keys) -> combine stills to sequence (or use single image) -> keylight in AE and composite – parent to null – eg. have null follow a stroke.
    Why I’m not happy:
    – well the green spill in some of the hand shots (-> might be resolved by increasing distance – which is not so easy in my small home studio and with the small green screen I’m using)
    – the unnatural shadows (hard edges and then doing a drop shadow in AE)
    What I would like to try:
    It would look most natural if I could just have the shots taken of the hand as it rests/simulates writing on a white sheet of paper. Then use a transfer mode (lighten/luminance??) to transfer the hand and the shadows to the grey paper background (see video above) in AE. Is that possible? Wouldn’t the background shine through the highlights of the hand? Could I remove the “shine through” problem by adding a second instance of the footage with a feathered mask along the border of the hand but this time use an “add” transfer mode?
    I guess I could just try, but before re-arranging my whole studio (risking to lose the current settings to match new footage with footage already taken), I thought someone more experienced might be able to tell me if the above “solution” appears viable. Or has anyone done something like this and can suggest a better work flow?
    Thanks and greetings from Liechtenstein,
    Johannes
    Stephen Smith replied 13 years, 9 months ago 2 Members · 3 Replies
  • Stephen Smith
    November 20, 2012 at 10:59 pm
    Play with the Screen Balance settings in Keylight. That increases or decreases the green spill color in a key.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Johannes Schwarz
    November 21, 2012 at 4:22 pm
    Thanks Stephen,
    I’ve been playing with the settings, but was not satisfied. I decided to do shoot some test samples outside the studio and use the method I described above. It is a more painful process to work with layers of duplicated and differently treated RAWs, but the result is definitely worth it.
    Johannes
  • Stephen Smith
    November 21, 2012 at 4:47 pm
    That’s great to hear. I’m happy everything worked out.
    Stephen Smith
