Activity Forums Maxon Cinema 4D Animation playback speed problem
  • Animation playback speed problem
    Posted by Eugene Dalarov on July 15, 2009 at 6:12 pm
    Got some wierd problem with the animation playback.
    It’s speed in the scene all of a sudden became very slow – about two times slower than it should be according to frame rate.
    I checked playable animation speed and project’s speed. Both ok.
    Polygon count is about 200.000 which should not be a problem for Radeon 4850 and Intel Quad Q9400.
    Any suggestions?
    Adam Trachtenberg replied 17 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 15, 2009 at 6:27 pm
    You’re talking about speed in the viewport? If so it could be any number of things. One thing you can do is click the icon at the bottom-right of the time slider and uncheck “all frames” in dialogue. That allows Cinema to drop frames in order to maintain the proper display speed.
