Activity Forums Maxon Cinema 4D Animation Offset with Mograph
  • Animation Offset with Mograph
    Posted by Glenn Takakjian on March 29, 2007 at 10:19 pm
    Is there away to Clone objects and randomly offset the Animations associated with them?
    I have an Xpression connecting Spline points to a Null as the Null passes by.
    I would like to duplicate the spline many times, Randomly Positioning and Scaling which I can do with the Random Effector
    But I would also like to randomize the Timing of the Animation so that they all seem to be moving at different times.
    I’ve tried the step effector but I’m not getting he results I’d like
    Any thoughts?
    TAK
    Adam Trachtenberg replied 19 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 30, 2007 at 4:12 am
    You should be able to use the Random Effector. In the Parameter>Other section, enter the number of frames you want to randomize in the Time Offset box. You also have to uncheck “Fix Clone” in the Cloner.
