Activity › Forums › Boris FX › animation keyframes
  • animation keyframes
    Posted by Matthew Beall on May 15, 2009 at 3:03 pm
    Sorry for such a simple question.
    I am working my way though the Boris Blue User guide.. Where you ‘animate an object’, for some reason my objects aren’t automatically adding keyframes. I see there is a toggle animate/static button, but whether it is on or off I can’t seem to add keyframes when I move/rotate/animate objects..
    -Matthew
    Matthew Beall replied 17 years, 4 months ago 2 Members · 2 Replies
  • Peter Mcauley
    May 15, 2009 at 8:10 pm
    Hi Matthew,
    The animate / static button should be RED when it is enabled. It should be enabled if you need keyframes. Also, you should probably go into the Keyframe Preferences and make sure that you have set the default interpolation to something other than Constant. Constant sets a constant state for the parameter and will eliminate any other keyframes in the effect for that parameter.
    I hope this helps,
    Peter.
  • Matthew Beall
    May 22, 2009 at 7:09 pm
    Thank you Peter,
    it was the ‘constant’ keyframe parameter that was throwing me..
    All working now!
    -Matthew
