Activity Forums VEGAS Pro Animation Keyframes effects window problem
  • Animation Keyframes effects window problem
    Posted by Davd Keator on May 18, 2011 at 5:08 pm
    Team, I have given Vegas 10d a try…
    Has anyone Noticed that the effects options no longer let you scrub the time-line? I mean how do you know where to attach your key-frames for the effects if you can’t see the timing when you scrub the bar? My preview monitor no longer moves when I slide in the effects window.
    Also, has anyone noticed the severe drop of GPU usage on the video cards?
    I tried Vegas 10a and now 10d.
    It has gone from 40% down to 4%
    Seems laggyer too now…
    4th try Vegas should work better not worse….
    President: http://www.VertexMedia.com
    Davd Keator replied 15 years, 3 months ago 2 Members · 2 Replies
  • Matt Crowley
    May 18, 2011 at 6:15 pm
    I don’t know about GPU usage, but for the keyframing you may have accidentally switched off Cursor Sync in the keyframe area of the effects windows. Look at the left-hand end of the keyframe area and you’ll see a small I-beam cursor and padlock icon. That toggles keyframe/timeline cursor sync on and off.
    Edit: just realized that (in Movie Studio 10 at least) the Sync Cursor option only enables/disables Timeline to effect window sync. Effect window to timeline sync seems to be permanently active. Maybe that’s what has been deactivated on your system?
  • Davd Keator
    May 21, 2011 at 2:27 am
    Figured it out… directx had an update that Microsoft chose not to install as regular updates…. fixed the problem…. now only if I could find my copy on 10c…
