Activity Forums VEGAS Pro Animation key-frames won’t stay put when I save and re-load a .vf file.
  • Animation key-frames won’t stay put when I save and re-load a .vf file.
    Posted by Jake Heneghan on January 18, 2012 at 12:40 am
    Hello. I’ve been using Sony Vegas Movie Studio HD 11 for some time now, and overall, it’s worked well. However, there’s one thing that’s been happening every time I save a file as a .vf and re-open it later on.
    If I’ve got any text media and have them fade, change colour, move, basically animate in any way using keyframes, when I save and re-load the file, the keyframes have gone from their original location to a position around eight times away from the original time.
    This happens every time I save a .vf file, and makes making any sort of animation a pain since if the program crashes for some trivial reason (eg trying to enable shadows on text), I have to re-do the entire thing again. Has anyone else had this happen to them, and is there a way to stop this from happening? I’m using Windows 7 64-bit, if that’s any help.
    Mike Kujbida replied 14 years, 7 months ago 3 Members · 3 Replies
  • Mark Barton
    January 20, 2012 at 5:28 am
    Looks like the latest build 521 resolves the keyframe issue. I set four of them and then saved the project and reloaded it fine.
  • Jake Heneghan
    January 20, 2012 at 7:24 pm
    Ah, okay. How would I get the latest build?
    EDIT: I just checked the Sony Creative site and looked up Movie Studio HD, the latest build is 37, but Vegas Pro is at 521, did you mean that one?
  • Mike Kujbida
    January 20, 2012 at 7:47 pm
    Jake, I’m sure that Mark was referring to Pro 11 and not your product.
    I recommend contacting Sony Tech Support via phone or email and explaining your problem in the hopes that they have a fix for you.
