Activity Forums Apple Final Cut Pro Legacy Animation footage in same Sequence as DVCPRO 50 footage
  • Animation footage in same Sequence as DVCPRO 50 footage
    Posted by Warren R sampson on December 3, 2007 at 3:22 am
    We are having some troubles mixing Animation footage from After Effects with DVCPRO50 footage in a sequence that has quite a bit of time remapping on the DVCPRO50.
    The Animation footage has gradients that show bands when the sequence is set to DV/DVCPRO50. The animation footage looks great when the sequence is set to Animation. But the DVCPRO50 footage with the time remapping is shifted in X and Y and shows flickering ghosts of multiple frames. We suspect the time remapping.
    Is there a sequence setting that will allow the animation to look good without having the time remapping mess up the DVCPRO50 stuff?
    Thanks much,
    Warren
    Thinking Moves
    Minneapolis
    Warren R sampson replied 18 years, 9 months ago 3 Members · 3 Replies
  • David Roth weiss
    December 3, 2007 at 3:29 am
    Pro Res 422
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Scott Skaja
    December 3, 2007 at 3:35 am
    In an 8 bit sequence you will more than likely get banding in gradients. First of all, if you have the opportunity, go back to AE and set you render settings to match the compression of your FCP sequence, in this case DVCPRO50, it will save you on rendering in Final Cut. Also, in AE add color Noise at 4% to your compositions. If non of these are options at 9:30 on a Sunday evening, add the noise to your AE renders in your FCP timeline.
    Scott Skaja
    edit/design/animation
    http://www.scottskaja.com
  • Warren R sampson
    December 5, 2007 at 1:15 am
    Thanks for the tips, guys. We will give the all a try.
    Warren
    Thinking Moves
