Activity › Forums › Adobe After Effects › animation effects/hologram look
Posted by Wisconsin on November 8, 2007 at 8:02 amI’m working with animation effects, trying to get a hologram effect with a picture. random blocks that continually change, can’t seem to get it to look right any suggestions ?
Dee Munsch replied 18 years, 10 months ago 6 Members · 9 Replies -
Bart Straman
November 8, 2007 at 9:10 amheey
i’m guessing this kind of hologram : https://www.geocities.com/~special_effect/holo_final.jpg
some sort of.
you mean, you can’t get the distortion right? or the whole look?Bart
Amit Zinman
November 8, 2007 at 11:34 amYou could use wiggle to do it along with some bad TV effect and some opacity.
David Modijefsky
November 8, 2007 at 1:38 pmI saw a tutorial about that a few years back. I can’t remember who made it. Try a search here on the Cow.
Wisconsin
November 8, 2007 at 2:17 pmI think I saw the same one but can’t seem to find it now Thanks
Wisconsin
November 8, 2007 at 2:22 pmI’m getting a distortion but it looks more collagie then semi transparent computer produced image
Bart Straman
November 8, 2007 at 3:21 pmI’m getting a distortion but it looks more collagie then semi transparent computer produced image
heey, what you could do is precompose your image and all your effects, distortions and then play with opacity or transfer mode options / blending modes of that precomposed layer so that you effect all your stuff, image, distortion etc.
if you search on google for “hologram” “after effects” you find alot of stuff.
Bart
Darby Edelen
November 8, 2007 at 4:04 pmI can tell you that you’ll want to use an additive blend mode on your pre-comp. Probably ‘Screen’ if you’re not working in a linearized color profile, I like ‘Add’ but it sometimes blows things out.
That said, AE has a couple of animation presets that can get you started on a look. Try searching the animation presets for TV.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Dee Munsch
November 13, 2007 at 1:46 am
