Activity › Forums › Apple Final Cut Pro Legacy › Animation Codec w/ Blackmagic Card
Posted by Lisa Rolley on April 4, 2008 at 4:28 pmHello
I cannot seem to get my ntsc monitor and FCP to play back sequences which are in the animation codec – i have the latest version of FCStudio and an SD Blackmagic card…the AE and 3D artists in my office kick out Animation Qt’s for me but i cant get them to play on the ntsc monitor.
While using other codecs when i set the video out to them properly they DO work …i just dont understand this. Should I be having designers kick out another format and if so will it be as hi res and full quality as animation qt’s?
Lisa
Jeremy Garchow replied 18 years, 5 months ago 3 Members · 14 Replies -
Chris Borjis
April 4, 2008 at 4:35 pmThough you can play back an animation codec quicktime in real time on a fast disk array, the codec itself is not supported
with hardware acceleration on any interface cards.what you have to do if you can’t render 10 or 8 bit uncompressed (if you have alpha channels etc…) just drop it into a 10 or 8 bit uncompressed timeline and render it to make it play in realtime. thats the only option I’m aware of.
Lisa Rolley
April 4, 2008 at 5:27 pmHey there Thanks for getting back to me you rock!
Ok so in this case there is no alpha so but then ideally i would have them kick out uncompressed 10 bit qt’s? Is the quality just as good as animation if not better and should i be requesting this format from AE & 3D guys and/or making qt’s out of tiff sequences from these guys?
I heard that the problem with these codecs is that unless you have a super fast raid system you cannot edit in real time – i even noticed this with the animation timeline this sluggishness.
Lisa Rolley
April 4, 2008 at 6:26 pmusually animators will give me animation codec qt’s that are 720×486 or 720×540 – i would like to know what format i should be bringing into final cut in order to have highest quality possible without the sluggishness that u get. I have an 8core macpro with 500gb storage on a 2nd internal sata drive.
I also do not understand the changing of compressing setting in sequence settings – if the qt’s are animation or uncompressed 10 or 8 bit and then i switch it to say JPEG, DV/DVCPRO or DVCPRO 50 when i have picture locked then want to switch back to full resolution will everything truly be at full quality again?
I know i seem pretty confused so i apologize for my lack of experience.
thank you for your time
L
Chris Borjis
April 4, 2008 at 7:31 pmthe black magic design website has the codecs for free download for mac or windows.
ask your clients to render to the 10-bit blackmagic codec.
you can drop those in the timeline and play without any rendering.
with todays faster systems you can indeed play a 10-bit uncompressed standard definition quicktime from even a usb external hard drive.
Lisa Rolley
April 4, 2008 at 7:39 pmAnd in terms of quality its still as good if not better – also you guys had mentioned alpha channels so if i get stuff with alpha can i also use blackmagic uncompressed 10 bit?
thanks so much for the help
best
Lisa -
Jeremy Garchow
April 4, 2008 at 9:15 pmWhat codec do you you usually FINISH your timeline in?
What avenue do you finish to? Tape? DVD? Web? iPhone? Silver Screen?
Chris Borjis
April 4, 2008 at 9:25 pm[lisa rolley] “And in terms of quality its still as good if not better – also you guys had mentioned alpha channels so if i get stuff with alpha can i also use blackmagic uncompressed 10 bit?”
well yeah, its 10-bit UNCOMPRESSED 🙂
Animation is basically the same thing just a bit smaller filesize and carries an alpha channel. You MUST use
Animation if you want alpha channels. -
Chris Borjis
April 4, 2008 at 11:34 pm[Jeremy Garchow] “Animation is 8bit.”
Thats something I don’t remind myself enough lately.
there you go lisa.
10-bit uncompressed will give you the edge above animation.
think smoother gradients.
