Activity Forums Compression Techniques Animation Codec to NTSC
  • Animation Codec to NTSC
    Posted by Brian Tetamore on September 18, 2008 at 2:36 am
    I’m editing a sequence that includes animation from another company. As requested they sent them as QT Animation No Compression 720×480 Lower Fields. The files play fine in QT Player.
    However, when I use them in my Motion 3 sequence the result is a slight stuttering motion. In Motion my project settings are the default NTSC 8Bit Uncompressed settings 720×480 Low fields. So everything should match up fine.
    I also tried to format the animations to an Apple Pro Res 10 Bit codec thinking I’d get better results. But when I play back the Pro Res version again you get this very subtle stuttering motion. To be clear, the footage is 3D camera movements through the interiors of various rooms.
    Can anyone suggest a workflow or explain why I’m having this issue? The end result is the mastered DVDs have spots in the animation sequences where there is noticeable stuttering. The rest of the video that I’ve created looks perfect.
    The Visual Rabbi
    Brian Tetamore replied 18 years ago 2 Members · 2 Replies
  • Daniel Low
    September 18, 2008 at 7:11 am
    Are you sure the animation clip they sent you is interlaced? Can you see the fields if you step through it frame by frame?
    Have you checked that both frame rates are the same (29.97fps rather than 30?)
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Brian Tetamore
    September 18, 2008 at 2:32 pm
    yes, good question. I asked the production company to format ntsc and lower fields. And the info in Quicktime player says 29.97 fps, and in Final Cut “Info” says it’s lower field. However, I don’t see fields. And when I import the original file into Compressor the Info pane says it’s progressive frames.
    My assumption is that it is not interlaced.
    The Visual Rabbi
