Activity Forums Adobe After Effects Animation codec / ProRes render problem
  • Animation codec / ProRes render problem
    Posted by Tim Snider on July 18, 2007 at 2:59 pm
    Hi folks.
    I’m working with 1280×720 ProRes HQ material in AE7, outputting to quicktime files using the Animation codec (Lossless module in AE). When I import into FCP2, the files look great in the viewer. But then when they are dropped into a ProRes HQ timeline, the resulting render looks horrible. LOTS of loss in the final timeline.
    I also just tested outputting directly to ProRes HQ from AE7 and I get the same thing. Am I missing something? Is this a Quicktime issue? It appears as if ProRes HQ is lossy between renders.
    Tim
    Tim Snider replied 19 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • David Bogie
    July 18, 2007 at 4:07 pm
    > I also just tested outputting directly to ProRes HQ from AE7 and I get the same thing. Am I missing something? Is this a Quicktime issue? It appears as if ProRes HQ is lossy between renders.< You might want to check in the FCP forums. ProRes has gotten lots of great and not-so-great ink. My first question would be are you sure you have your render handlers set up properly in FCP? bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Scott Roberts
    July 18, 2007 at 4:33 pm
    Is pulldown an issue here? Animation: 4:4:4, ProRes 4:2:2.
  • Tim Snider
    July 18, 2007 at 4:49 pm
    Pulldown typically refers to 3:2 pulldown. Frame rate is 23.98 in and out in my case. But if you mean color difference between 4:4:4 and 4:2:2, I’m not sure.
    It’s strange to me that the Animation codec looks good in the viewer and in the final render in the timeline.
    Any clues?
  • Tim Snider
    July 18, 2007 at 5:02 pm
    Correction:
    I meant to say “…NOT in the final render in the timeline” in that last post.
  • Tim Snider
    July 18, 2007 at 5:49 pm
    We’re viewing the image on the Panasonic BT-LH2600 hi def broadcast monitor.
  • Tim Snider
    July 18, 2007 at 10:33 pm
    Interlacing isn’t a problem here.
  • Tim Snider
    July 19, 2007 at 2:17 am
    So NO ONE has run into this problem?! Can anyone at Apple, Adobe or otherwise confirm that ProRes can make the round trip FCP2->AE7->FCP2 without loss? Or is it known to be lossy?
    Thanks for any help.
  • Steve Roberts
    July 19, 2007 at 4:47 am
    Recently Adolfo posted a link from here to Capria.tv that seemed to indicate that the codec is best avoided for a while.
  • Tim Snider
    July 19, 2007 at 12:45 pm
    Thanks, Steve. Frank Capria’s article is confirmation of that. The workaround he suggests for the time being is transcoding clips to the Animation codec with Final Cut
