Activity › Forums › Apple Final Cut Pro Legacy › animation codec in fcp
Posted by Jason Leue on July 17, 2008 at 10:01 pmI was wondering if there’s a way to play mov’s with the animation codec real time in the fcp timeline?
thanks
JasonJason Leue replied 18 years, 2 months ago 6 Members · 9 Replies -
Mike Johnson
July 17, 2008 at 10:11 pmYou can also create a sequence with the same settings as the QuickTimes you are using.
Mike Johnson
Final Cut Pro Editor
Drury Outdoors
http://www.druryoutdoors.com -
Shane Ross
July 17, 2008 at 10:14 pmBear in mind that the Animation codec has a high data rate…you will need a fast RAID to play these back. Talking uncompressed HD 10-bit data rate here. The Animation codec wasn’t meant for playback and editing, it was meant as a lossless codec for making graphics with alpha channels and keeping footage lossless between applicaitons and platforms.
Shane
Read my blog, Little Frog in High Def -
Jason Leue
July 18, 2008 at 2:38 amok so when I create a new sequence which setting would I use to use the animation codec?
thanks
Mike Johnson
July 18, 2008 at 1:16 pmIf your using FCP6, when you drop your first clip into a sequence it will ask if you want to match the sequence settings to the clip settings.
If your not using FCP6, you will need to figure out what the settings are for your clips and create a sequence to match. If you right click on the clip in your browser and select Item Properties > Format you find the info you need.
Mike Johnson
Drury Outdoors
Jeremy Garchow
July 18, 2008 at 1:45 pm[Shane Ross] “The Animation codec wasn’t meant for playback”
Not only that it’s antiquated at only 8bits/channel.
Jason, what are you trying to do?
Jeremy
Peter Wiggins
July 18, 2008 at 3:04 pmFCP uses a different render path to the normal RT engine when an Animation codec sequence is selected. This will mean that a different image has to be rendered for the external monitor and the canvas window that is why you will see stuttering and or a lag.
Peter
Jason Leue
July 19, 2008 at 2:17 amwhen I start a new project it asks “select sequence preset” do i just pick anyone?
Then when I drag the animation clip in the sequence it will change the settings to match?
sorry this should probably in the basics forum.
thanks alot
Jason Leue
July 19, 2008 at 10:54 pmOk I think I got it.
Strange but it works. I made a sequence with the apple pro res seetings, then when I added a new clip with animation settings it was fine. So the preset doesn’t really matter I guess? Then why ask me what setting I what?
