Activity Forums Maxon Cinema 4D Animation Basics
  • Animation Basics
    Posted by Dale Anderson on November 8, 2009 at 3:09 pm
    Gudday! What a great forum, thanks to everyone for contributing. I’m new at this so forgive my ignorance. I’m trying to move an object, hav it pause, then move again. How do I do this? I know how to make it move, place the keyframes, etc. But when I try to make it pause I have problems as it just continues on to the next keyframe. If I place another keyframe say 30 frames out but don’t move the object, the onject wobbbles in space. Please help.
    Adam Trachtenberg replied 16 years, 10 months ago 3 Members · 3 Replies
  • Chris Martin
    November 8, 2009 at 3:35 pm
    Dale,
    You need to create 2 identical keyframes at 2 points on the timeline where you want the stop to occur. Then you will need to go into the FCurves and select the 2 keyframes and select Clamp…this should stop the moving about.
    Regards,
    Chris
    Regards,
    Chris Martin
    http://www.kreativedomain.com
  • Dale Anderson
    November 8, 2009 at 4:12 pm
    Much appreciated Chris! And thanks for the speedy response. I’ll try itout and let you know. Thnx again.
  • Adam Trachtenberg
    November 9, 2009 at 3:59 am
    Another option would be to set the keyframe where you want the object to rest to step interpolation.
