Activity Forums Apple Final Cut Pro Legacy Animation and editing
  • Animation and editing
    Posted by Lucas Barros on May 19, 2009 at 12:03 am
    Hey there everyone,
    Here’s my problem:
    I have a video to edit that will use CGI quicktime MOVs rendered using Animation Codec (1280×960 30fps).
    My final product wil have to be a QT with the same specifications.
    What is the best way to do this?
    I was thinking in converting the Animation Movs, editing and then substituting them in the “capture” folder before exporting, if that’s a good idea, which coded should I convert the original files to?
    Any better suggestions in what to do?
    Txs for the time and help!
    My machine is a
    Macbook Pro
    2.5Ghz IC2D
    2Gb Ram
    200Gb-7200rpm HD
    NVidia GeForce 8600M GT
    Lucas Barros replied 17 years, 3 months ago 2 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    May 19, 2009 at 4:08 am
    Hi Lucas,
    1280×960 is a very strange size.
    How do you intend to deliver your movie?
    Rafael
    http://www.nagavideo.com
  • Lucas Barros
    May 19, 2009 at 11:59 am
    Well, I have to deliver a QT, codec animation and 1280×960 30fps, that is; the same specifications as the original files.
    This file will be converted for web and TV use but my client wants the Best Res they have for master.
    What would you do?
    cheers
    Lucas Barros
    http://www.flickr.com/capangadocapeta
    Macbook Pro
    2.5Ghz IC2D
    2Gb Ram
    200Gb-7200rpm HD
  • Rafael Amador
    May 19, 2009 at 12:49 pm
    Hi lucas,
    If you have to finish with that size, edit in that size.
    Drop your animation to any sequence and conform the sequence to the clip.
    Be careful with the field order. FC probably will interpret your animations as Upper first.
    When you have your sequence ready I think you should change the codec to ProRess and edit in that codec. I think you will have more RT than with Animation.
    rafael
  • Lucas Barros
    May 19, 2009 at 8:23 pm
    Txs man,
    but when I do that it asks for render in every file.
    I was thinking of converting the files to PhotoJpeg but with the same size and frame rate.
    Then, after all is done, I substitute de converted files with the original ones.
    I will test that option and write my “discoveries” here.
    see ya!
    Lucas Barros
    Macbook Pro
    2.5Ghz IC2D
    2Gb Ram
    200Gb-7200rpm HD
  • Rafael Amador
    May 20, 2009 at 1:59 am
    I think is a good option. With Animation you have no RT at all.
    rafael
  • Lucas Barros
    May 20, 2009 at 1:52 pm
    Well,
    I converted one file as a test to various formats,
    the best option I think will be work in H264 and then do the substitution.
    I really hope it will work.
    I’ll keep this thread posted with the follow up.
    Txs for the help Rafael.
    Cheers
    Lucas Barros
    Macbook Pro
    2.5Ghz IC2D
    2Gb Ram
    200Gb-7200rpm HD
  • Rafael Amador
    May 21, 2009 at 1:50 pm
    Hi Lucas,
    H264 is very risky option if you intend to bring it to FC.
    Is not an editing codec and there are too may reports of crashes.
    I would try something more classic, DV or so.
    rafael
  • Lucas Barros
    May 21, 2009 at 4:29 pm
    Is that so?
    Wasn’t aware…
    Well, what you think about AIC?
    I converted to ProRes too but it gave me a huge file,
    as long as I have to do this I think it’s better to convert them to small ones right?
    It’s only for “off-line” anyway.
    AIC gave me a good size.
    Original Animation file 460mb
    AIC 50mb
    H264 11mb
    Jpeg100 160mb
    ProRes 130mb
    Will try the DV now.
    Cheers man!
    Lucas Barros
    Macbook Pro
    2.5Ghz IC2D
    2Gb Ram
    200Gb-7200rpm HD
