Activity Forums Maxon Cinema 4D Animatingwater w/o MoGraph – Please HELP!
  • Animatingwater w/o MoGraph – Please HELP!
    Posted by Donna Arbogast on February 22, 2010 at 8:52 pm
    I have to complete a “How it Works” animation for a solar pool heater. I’ve searched the web for tutorials on how to animate the water, but they all require MoGraph, which I do not have.
    PLEASE HELP!! I’ve attached a sketch of my artwork & What I need the water to do, but just to be clear:
    1 – The cold water flows up the pipes on rt
    2 – The water fans out through the panel array getting hooter as it goes along. I have to change the color of the water from blue to red to convey heat
    3 – The heated water returns to the pool.
    Sounds easy, but can’t figure it out!
    Randy Johnson replied 16 years, 7 months ago 2 Members · 3 Replies
  • Randy Johnson
    February 23, 2010 at 11:00 am
    I would just do it with a sweep nurbs that gets aniamted. Then apply a nice water texture to it (bump and displacment.
    It you need a little running water. You can do this with a simple emitter and a gravity effector. THen you add a motion blur tag and set it to vector blur.
    /Randy
  • Donna Arbogast
    February 23, 2010 at 2:08 pm
    Ok. I finally got a Sweep Nurbs to work, have my water texture applied – now how do I animate it? I tried animating just the points on an object before by adding key frames & moving the points. It didn’t work. The object through out the animation was altered.
    I’m still learning the program, so I’m probably missing something simple.
    Thank you for your help.
  • Randy Johnson
    February 23, 2010 at 4:15 pm
    In the sweep nurns attributes there is END GROWTH it is default to 100%. THats what you want to animate.
    I made a five minute tutorial on how i would set it up including a user data slider incase you have several thing you want to control.
    https://rootvisuals.blogspot.com/
    /Randy
