Activity Forums Zaxwerks animating words instead of letters for text animation presets
  • animating words instead of letters for text animation presets
    Posted by Joe Moya on June 23, 2008 at 3:48 am
    OK, I give…
    I have look every place… read everthing I could…
    And… have not been able to find a way to make annimation presets change from animating each letter of a work to each work being animated.
    At present, the only solution I have found is to create a new track for each letter for each word and apply the animation. Unfortunately, this is very time consuming and almost impossible to make words fall into place properly in a 3D area… the letters for each word are frequently out of line and not even.
    Anyone have a solution or at least point me to a tutorial that will help create animated word groupings instead of each letter as standard for the animation presets.
    Joe
    Joe Moya replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    June 26, 2008 at 12:37 am
    Hi Joe,
    I believe your answer will be found in the advanced options.
    Choose one of the transition segments in the timeline. Next, look for the transition grouping pop-up menu. You can choose to group your text by word, by paragraph and by many other options. Alternately, you could select certain letters and make a hard group out of that.
    Does this help?
    Jon
  • Joe Moya
    June 26, 2008 at 1:46 am
    Thanks… that’s it… except I found that it sometimes (for what ever reason) doesn’t work and gives a “First select an object, then choose this command”… so, I have to go to the text part of the track and select the objects.
    Joe
