Activity › Forums › Adobe After Effects › Animating vs. Camera Moves?
  • Animating vs. Camera Moves?
    Posted by Josh Pigford on June 20, 2010 at 5:55 pm
    I’m wondering, maybe from a “best practices” stand point…when is it best to use animation vs. camera moves.
    Take this typography piece: https://vimeo.com/3094616
    When doing something like that…would you recommend just doing most (if not all) of that animation purely setting position keyframes on the text? Or would you have a camera moving/rotating/tilting/etc?
    Just not sure when it’s best to animate the object itself or use the camera for that.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Steve Roberts replied 16 years, 3 months ago 2 Members · 1 Reply
  • Steve Roberts
    June 21, 2010 at 11:00 am
    I like using the camera, with auto-orient off. If you like the snappy style of animation, you could set a key for the camera, then make the next key (pos/rot) maybe 3 frames later, as a hold keyframe. Copy that one and paster it later, then make it a non-hold key. Three frames later, make the new key. So it goes AB…BC…CD…DE… and so on. You could add a wiggle expression if you want.
