Activity Forums Adobe After Effects Animating the same graphic – but at a larger resolution?
  • Animating the same graphic – but at a larger resolution?
    Posted by Michael Becke on November 29, 2006 at 4:39 pm
    Hi, here’s a tricky one that I just can’t seem to get my head around…
    I have animated a large image (3000×4000) as a background on a small comp. (720×408)
    The “camera” moves from one location of the image to the next on the beat.
    Now the client has given me a larger version of the same thing… (about 15000×20000) because they want to be able to zoom really close to the image without pixelisation.
    I’ve worked on the animation already and don’t want to start again/modify every position… but if I replace the image with the large one, the section of the image that is currently visible isn’t the same.
    So… is there a way to have a layer/composition the same size, but have the effect of having a higher dpi. (more information on the same layer size)
    Michael
    Michael Becke replied 19 years, 9 months ago 12,127 Members · 1 Reply
  • Michael Becke
    December 1, 2006 at 10:01 am
    I thought this may be the case and thianks for the input. 🙂
