Activity › Forums › Adobe After Effects › Animating text with sliders
  • Animating text with sliders
    Posted by Josh Smith on March 11, 2013 at 1:51 pm
    Hi everyone,
    I would like my text layer to count up from 0 to 1,800,000 over the course of 60 seconds. I have tried to use a slider control, but I can only get it to go up to 1,000,000. How can I fix this?
    Also, how do I only animate part of the text? So, for example, I have it saying: “Time elapsed: 0 seconds”, and I would like it to animate just where the “0” is, from 0 to 60, and the rest stays the same.
    Also, how can I add commas into the animated numbers? So that I get 1,800,000 and not 1800000?
    Thanks for your help!
    Josh.
    Todd Kopriva replied 13 years, 6 months ago 4 Members · 3 Replies
  • Joseph W. bourke
    March 11, 2013 at 2:05 pm
    I think that, in your case, Expressions are going to fill the bill. Here’s a link to the expression, and a way to get numbers over a million:
    https://www.videocopilot.net/forum/viewtopic.php?f=5&t=78872
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • John Cuevas
    March 11, 2013 at 2:22 pm
    If instead of using a slider, you use Effects > Expression Controls > Angle Control, you can go over 1,000,000. I have no idea why angle control can do this and slider can’t, but it’s a good little work around.
    So use the counter link that Mr. Bourke provided, but in the directions where it says use a slider, just change that to angle control.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Todd Kopriva
    March 12, 2013 at 12:33 am
    There’s no good reason for the slider control value to max out at 1,000,000. I’ll see if I can fix that.
    After Effects team blog
