Animating Text On A Path
Hello all and thank you in advance
I am new to cinema 4d and I am trying to animate text on a path, the text comes from illustrator. the problem that I am having is that the letters are broken up into three different paths (it was designed that way), so when I add the word to the fracture object and then add the spline effector the letters get broken up into the three different parts, is there a way to merge these three path of each letter so that when i apply the fracture and the spline effector the three parts are seen as one?Juan Obregon
