Activity › Forums › Adobe After Effects Expressions › Animating text, by character AND by word
  • Animating text, by character AND by word
    Posted by Christopher Rutherford on April 26, 2021 at 6:39 pm
    So I’ve got a lot of text that I’m trying to animate in by marker. I was wondering if there was a way to configure it such that each layer marker triggers an animation for a word, but that individual word animates in randomly per character.
    For example, in the text layer “ROSES ARE RED”
    Marker one would trigger animation for S then O, then R, then S, then E
    Marker two would trigger R, then A, then E
    Marker three would trigger R, then D, then E
    Is this even possible? Is this a dream unreachable?
    priscila johanna replied 5 years, 3 months ago 3 Members · 5 Replies
  • Filip Vandueren
    April 27, 2021 at 12:20 pm
    There’s probably a complexer way to calculate it all within 1 expressionselector, but you could do this more easily with 3 range selectors:
    1 random transition,
    1 to “protect” words that have already been revealed
    1 to keep hidden words that should not yet be revealed.
    See attached project.
  • Christopher Rutherford
    April 27, 2021 at 5:16 pm
    Incredible. Would never have thought to do it like that. Thank you so much.
  • priscila johanna
    June 24, 2021 at 3:04 am
    Hello, very good, this code I congratulate you, maybe you can help me (image attached) I want to have that result but with lines of texts, how can I do it, I only have the code that is here
    m = thisLayer.marker;
    i = m.nearestKey (tiempo) .index;
    if (m.nearestKey (hora) .hora> hora) {i–;}
    si (i <1) {i = 1};
    I–;
  • Filip Vandueren
    June 24, 2021 at 9:55 am
    Your setup is a bit different than Christopher, because the sourceText is changed by the markers.
    maybe you can try something like this:
    (Copy and paste this onto the selected text-layer, it is not an expression)
    Adobe After Effects 8.0 Keyframe Data
    Units Per Second 25
    Source Width 1
    Source Height 1
    Source Pixel Aspect Ratio 1
    Comp Pixel Aspect Ratio 1
    Text Animators Animator #2 Selectors Range Selector #1 Offset #3
    Frame percent
    -100
    Expression Data
    i = m.nearestKey(time).index;
    if (m.nearestKey(time).time > time){ i--;}
    linear(time,m.key(i).time, m.key(i).time+0.5,-100,100);
    End of Expression Data
    Text Animators Animator #2 Selectors Range Selector #1 Advanced Ease Low
    Frame percent
    60
    Text Animators Animator #2 Selectors Range Selector #1 Advanced Randomize Order
    Frame
    1
    Text Animators Animator #2 Selectors Range Selector #1 Advanced Shape
    Frame
    2
    Text Animators Animator #2 Properties Opacity
    Frame percent
    4
    Text Animators Animator #2 Properties Position
    Frame X pixels Y pixels Z pixels
    0 -132 0
    Text Animators Animator #3 Selectors Range Selector #1 Offset #3
    Frame percent
    -100
    Expression Data
    if (i==m.numKeys) {
    100
    } else {
    linear(time,m.key(i+1).time-0.5, m.key(i+1).time,100,-100);
    Text Animators Animator #3 Selectors Range Selector #1 Advanced Ease Low
    Frame percent
    60
    Text Animators Animator #3 Selectors Range Selector #1 Advanced Randomize Order
    Frame
    1
    Text Animators Animator #3 Selectors Range Selector #1 Advanced Shape
    Frame
    2
    Text Animators Animator #3 Properties Opacity
    Frame percent
    4
    Text Animators Animator #3 Properties Position
    0 132 0
    End of Keyframe Data
  • priscila johanna
    June 24, 2021 at 2:51 pm
    hi Filip
    Thank you very much for taking your time and helping me I get an error in the expression, could you upload a file if it is not too much trouble please?
