Activity Forums Adobe After Effects Animating text around a circle
  • Animating text around a circle
    Posted by Shannon Mcclean on June 24, 2009 at 2:16 pm
    I’m looking to animate text round a circle, and have no idea how to do it. Ideally I want to animate it in 3D round a globe shape like the way the ‘daily planet’ text revolves around a globe. Any ideas?
    Cheers,
    Shannon
    flickr.com/freekorps
    Todd Kopriva replied 17 years, 2 months ago 4 Members · 3 Replies
  • Michael Szalapski
    June 24, 2009 at 3:55 pm
    One way is to:
    Make a path in the shape of a circle.
    Use text on a path and put text on the path.
    Then create your circle.
    Create a null.
    Make the text, circle and the null 3d.
    Parent the text to the null.
    Animate the rotation of the null to make the text rotate around your circle..
    Make another null (and make it 3d too)
    Parent the first null to this second one. Rotate this second null to get your text at the angle you desire.
    That should do it. There, of course, are other ways.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Camp
    June 24, 2009 at 3:59 pm
    there is a text preset called ‘3d rotate around a circle’ that will do what you are looking for. open the effects & presets window and type that preset name in and then apply in to a text layer. you’ll then want to rotate the layer’s x-axis to see it better.
    you may have some problems getting a ‘globe’ in the middle of that text. if that is what yo need to do, you might instead apply the cc sphere or cc cylinder effect to the text layer (without the preset). both of these will allow you to set a render option to inside or out side, allowing you to ‘split’ the text layer into halves so you can place an object in between them.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    June 25, 2009 at 3:05 pm
    Here’s a thread that addresses the same question and links to an example project:
    https://forums.creativecow.net/thread/2/916303
    I found this using this After Effects Community Help search.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
