Activity Forums Adobe After Effects Expressions animating swinging hair (basically object on a swinging rope)
  • animating swinging hair (basically object on a swinging rope)
    Posted by Joel Benjamin on December 15, 2010 at 6:11 pm
    I have a a character with a ponytail. I have been key-framing the pony tail swinging animation but considering this is a 45-minute long film it’s going to get REALLY tiring. Not to mention the fact that animating it all by hand is not EASY.
    I’m fairly expression-savvy and have tried a couple of methods of doing this with expressions but haven’t found anything working super well.
    My initial thoughts were —
    Have the pony tail look at a null layer that’s always on the ground (its x-position parented to the character’s center of gravity)
    Obviously then the hair is too static so I need to somehow add some “spring” to the lookAt to give it some motion and decay. A very dynamic pendulum of some kind.
    Anyway, I haven’t had a ton of luck getting it just right.
    Thoughts?
    cheers
    Joel
    Joel Benjamin replied 15 years, 9 months ago 2 Members · 2 Replies
  • Chris Wright
    December 17, 2010 at 5:25 pm
  • Joel Benjamin
    December 17, 2010 at 9:46 pm
    Forgive me for being a tad confused by this reply… Are you linking specifically to your particular comment? This seems to be just a kind of spring expression for position, but not really what I’m looking for
    I kinda figured it out and ended up using a variation of Filip Vandueren’s expression for shirts swinging on a moving clothes line which tracked the speed and movement of a parent layer and applied that velocity to rotation, taking into account some dampeners and weight.
    I started with a Controller Null with 3 expression controllers on it – one each for inertia, stiffness and mass.
    Because the head itself was parented to the neck of the character I couldn’t figure out an easy way to track its velocity at time (I could track the POSITION velocity at a specific time, but couldn’t track the anchorpoint’s velocity at a specific time, which was necessary because I needed the Worldspace coordinates instead of local space as the head was parented to the neck). To solve this, I had another Null (“PonytailPosition”) with its position linked via expression to the worldspace coordinates of the back of the head:
    target=thisComp.layer("ponyTail");
    target.toWorld(target.anchorPoint);
    Then I applied the following to the pony tail’s rotation
    inertia = thisComp.layer("CONTROLLER").effect("inertia")("Slider");
    stiffness = thisComp.layer("CONTROLLER").effect("Stiffness")("Slider");
    mass=thisComp.layer("CONTROLLER").effect("mass")("Slider");
    //these are the sliders attached to the Controller null.
    //I had to play around with the actual variables quite a bit to get
    //the best result, ending up with: .85, .05 and 18 respectively
    lagValue = calcValue(0);
    f= thisComp.frameDuration;
    will=0;
    for (t=0; t<=time; t+=f) {
    delta = calcValue(t) - lagValue;
    will = will * inertia + delta*stiffness ;
    lagValue +=will
    lagValue;
    function calcValue(t) {
    return -thisComp.layer("N_PonytailPosition").position.velocityAtTime(t)[0]/mass;
    Again if the parent (the head, in this case) wasn’t not already a child of another layer, I wouldn’t need to link it to another null, I could just pull the position.velocityAtTime right from the head. But because its local position isn’t actually changing, I needed to convert that to world space via another Null. There’s possibly a more efficient way to do this but this worked fine. Thanks once more to Filip Vandueren for the original script
