Activity Forums Adobe After Effects animating strokes
  • animating strokes
    Posted by Carlos Cidre on October 6, 2008 at 4:29 pm
    hello everyone,
    so i want to animate a stroke as if it were drawing itself over time. ive used the solid layer, generate stroke technique and while it does provide the desired effect, i cant composite it over something else since its a solid layer covering everything underneath it. is there another way to do this? is there a way to maybe key out the solid and just keep the path with the stroke generator doing its thing?
    thanks for all your help in advance!
    Roland R. kahlenberg replied 17 years, 11 months ago 3 Members · 2 Replies
  • Grant Swanson
    October 6, 2008 at 4:39 pm
    If you set the solid color to black, and the stroke to white, you can set the other layer (the one you want to reveal) to use the stroke as a luma matte.
    Grant Swanson
    Visual Effects Supervisor
    Video Apex – Minneapolis, MN
    videoapex.blogspot.com
  • Roland R. kahlenberg
    October 6, 2008 at 4:43 pm
    Most of the effects within AE’s Effect>Generate category has an option to only view
    (1)the result of what is generated
    (2)a composite of what is generated together with the source layer’s original content
    (3)or to reveal the original content using the generated elements
    (4) or variations of the generated content together with the original content
    Look out for the parameters that allow you to set these options. For Effect>Generate>Stroke, you’ll find these options within the Paint Style parameter.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
