Activity Forums Adobe After Effects Animating still images causes flicker lines
  • Animating still images causes flicker lines
    Posted by Jasonm on January 23, 2007 at 9:01 pm
    Animating still pics works fine until things move fast, then I get horizontal white flickers. Small, but annoying.
    I’m rendering for dvd with AE7, ntsc, resolution is high, source files are psd, outputting as quicktime. I did a forum search but maybe used the wrong terms. Please help if you can.
    Jasonm replied 19 years, 8 months ago 2 Members · 3 Replies
  • Kevin Camp
    January 24, 2007 at 12:49 pm
    if you have photoshop there is an action set that works well to reduce interlace issues with still images. it will selectively blur the problem areas rather than the whole image. however, it may work best if you have the image scaled to the final output size.
    you can download it here:
    http://www.adobeevangelists.com/deflickerator.zip
    you also may be able to pick appart the action steps and recreate in ae.
  • Jasonm
    January 24, 2007 at 1:55 pm
    Awesome, thank you very much! I’ll give it a try!
  • Jasonm
    January 24, 2007 at 1:56 pm
    Excellent, I believe this may have solved the problem, thanks!
