Activity Forums Adobe After Effects Animating Speakers to Sync with Audio
  • Animating Speakers to Sync with Audio
    Posted by Awal on June 10, 2005 at 5:46 am
    I’m working on a 24p mini-dv music video that needs an effect. I need to animate a set of speakers to pulse and vibrate in sync with the music, this will then be composited to a performance against a green screen. Where do I begin?
    Filip Vandueren replied 21 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    June 10, 2005 at 8:15 am
    Import the audio and “animation > Keyframe Assistant > Convert Audio to Keyframes”.
    You get a new layer with sliders that hold values corresponding to the amplitude of the audio.
    ou can use a simple pixkwhip expression to use this value in the scale of a layer or a bulge-effect etc.
