Activity › Forums › Adobe After Effects Expressions › Animating several brush stroke offset time expression
  • John Mangual
    April 2, 2015 at 12:48 am
    I have AE CS6 and I get error when applying expression. I though this script is what i’m looking for but maybe I’m going about it wrong.
    Basically I’m trying to apply a stroke using an expression so i can manipulate it. Ways I plan to manipulate them is adding more strokes offset from the previous (using same contour). I want to have all strokes, say 2px width and 10px apart. Another plan is to increase/decrease space after each stroke.
    So..
    1st stroke is 10px offset
    2nd stroke is 9px offset
    3 is 8 and so on.
    I’m able to achieve this manually but very time consuming as you can imagine. Is this feasible or should i stick to manual?
    Thanks.
  • Dan Ebberts
    April 2, 2015 at 6:32 am
    What you’re asking is a little vague, but I think it’s do-able (and should work fine in CS6). Here’s a quick example. Create a brush stroke on a layer. Add this expression to the Position property of the Brush’s (not the Layer’s) Transforms:
    myIdx = thisProperty.propertyGroup(2).propertyIndex;
    delta = [(myIdx – 1)*10,0]
    value + delta
    Duplicate the brush a bunch of times. Each new brush should be offset 10 pixels to the right of the previous brush.
    Dan
  • John Mangual
    April 2, 2015 at 5:39 pm
    Sorry for the confusion. Here is what i want to do.(attached)
    Can this be done with “Stroke Effect”, not brush, in an expression?
  • Dan Ebberts
    April 2, 2015 at 6:10 pm
    The only way I can think of to do that would require a script to do the mask expansion. It would be straightforward I think, but a bit of work. Maybe someone else will have a better idea.
    Dan
  • John Mangual
    April 9, 2015 at 12:39 am
    Thanks for the idea. I gave it a shot but couldn’t really get it to work. Guess I’ll go back to the manual method.
    Is there an expression just to add a stroke i can play around with?
  • Dan Ebberts
    April 9, 2015 at 12:45 am
    No, expressions can’t create anything–they can only manipulate the value of the property hosting the expression.
    Dan
Page 2 of 2
