Activity Forums Adobe After Effects Expressions Animating scale of multiple groups within a shape layer in a random configuration
  • Animating scale of multiple groups within a shape layer in a random configuration
    Posted by Jackson Davis on April 27, 2017 at 3:17 pm
    Hello there,
    So I have a world map vector constructed of circles, imported into AE, converted to a shape layer. I now have 1 shape layer (called ‘map’) containing 735 groups (each being a separate circle, named ‘Group 1’, ‘Group 2’ etc).
    I would like to have the map transition into the frame by each circle scaling from 0-100%, but in a random, staggered order. As opposed to all of them scaling at the same time. Ordinarily, I would do this manually, but with there being 735 groups this obviously isn’t a sensible idea.
    I’ve never really worked with any expressions beyond the basics, so I’m pretty excited to delve into this section of AE and utilise them properly.
    Many thanks in advance, I have tried to find a solution elsewhere, but unfortunately I haven’t found anything (maybe I’m looking in the wrong place)
    Jackson Davis replied 9 years, 4 months ago 3 Members · 6 Replies
  • Steve Sierra
    April 27, 2017 at 6:06 pm
    You can put this in every group’s transform/scale :
    var minGoTime=0;
    var maxGoTime =5;
    seedRandom(800, true);
    var goTime = random(minGoTime ,maxGoTime );
    var spd = 10;
    var a = clamp((time-goTime)*spd, 0, 100);
    if(time
  • Dan Ebberts
    April 27, 2017 at 6:26 pm
    Play around with this:
    minStart = 0;
    maxStart = 2;
    rampDur = .25;
    n = parseInt(thisProperty.propertyGroup(2).name.split(” “)[1],10);
    seedRandom(n,true);
    myStart = random(minStart,maxStart);
    ease(time,myStart,myStart+rampDur,[0,0],[100,100])
    Dan
  • Steve Sierra
    April 28, 2017 at 3:52 am
    Hi Dan,
    Could you quickly explain what parseInt does ?
    I read it takes a string and turns it into an int ? How ? What does the base 10 do ?
    Thanks !
  • Dan Ebberts
    April 28, 2017 at 6:20 am
    That’s what it does. It will parse the string from left to right until it reaches the end of the string or a character that doesn’t translate to an integer. So “23x” would parse as 23, as would “23.123”. If the first character can’t be parsed ( “x123”, for example) parseInt returns NaN (not a number) and you should check for this using isNaN() if that’s a possibility with your set up. The 10 just ensures that the string is interpreted as a base 10 number.
    Dan
  • Steve Sierra
    April 28, 2017 at 7:10 am
    I see,
    I was confused, thinking it might turn “a” to “1”, “b” to “2”, “c” to “3”, etc…
    Thanks for the lesson !
  • Jackson Davis
    April 28, 2017 at 7:54 am
    Thanks for your help guys, I really appreciate it.
    Dan, your method is working like a charm – Exactly what I was looking for. Thank you also for the explanation.
