Activity Forums DaVinci Resolve Animating PNG files and exporting without background help?
  • Animating PNG files and exporting without background help?
    Posted by Lyndon Minor on March 15, 2021 at 3:52 pm
    I have 5 png files of a 16 bit torch that need animating from 1 png to the next. I put all 5 in the timeline and rendered it straight away as a mp4. it plays perfectly in streamlabs obs. Though it is not transparent so after hours of research It still doesnt work using export alphas and so on it renders it as a still png. can someone help
    Tero Ahlfors replied 5 years, 5 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    March 16, 2021 at 5:18 am
    You will need to use a format that has alpha channel support and works in OBS. Also the single clip alpha export is a fairly new feature so you’ll need the latest Resolve. Before alpha channel export only worked on when exporting individual clips.
