Activity Forums Adobe After Effects Animating paths
  • Animating paths
    Posted by Hayley Warren on February 13, 2015 at 6:58 pm
    What would be the best tools to use to have my arrow animate out from bottom to top?
    I imagine it would need to work like trim paths. I have tried the omino snake plugin to animate arrows but I need to maintain the angle shown in the image, which is why I am using paths.
    Also, am I able to change the key point on this path (with the two overlapping squares) to be the head of the arrow? How would I do this?
    Kevin Camp replied 11 years, 7 months ago 2 Members · 1 Reply
  • Kevin Camp
    February 13, 2015 at 7:53 pm
    that double box point is the first vertex point. if you were to draw a path with the pen tool, you’d notice that the first place you click will create a point with that double box.
    it is also the point where an effect that uses mask paths (like stroke) or a mask property (like trim paths) starts from.
    you can change it by selecting a different point on the mask or shape an choose layer>mask & shape>set first vertex.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
