Activity Forums Adobe After Effects animating multi-layer text like handwriting
  • animating multi-layer text like handwriting
    Posted by Staci Daniel on April 21, 2009 at 9:52 pm
    Ok… I am very new to after effects. I have taught myself how to animate words so that they appear to be written in (like script or a signature) BUT… I HAVE A MORE SPECIFIC PROBLEM:
    I made words out of wire wrapped in yarn, photographed them, green screened the background away in photoshop and split each letter into layers so that the rope letters overlap appropriately.
    I need the letters to “write” themselves in my composition (I used a stroke set to reveal original image… keyframe start: 0; end: 0 then transition to a keyframe start: 0; end: 100. This will effectively “write” letters, but it makes it so that the under layer of my yarn shows up along with the top layer… i.e. exposing parts of the scripted yarn text ahead of time that shouldn’t be shown yet.
    Is there a way to make sure that a stroke mask ONLY affects ITS layer, and not unfortunate layers that just happen to cross its path? I’ll keep searching the tutorials for answers.
    HELP!
    Staci
    Staci Daniel replied 17 years, 4 months ago 3 Members · 3 Replies
  • Jeremy Allen
    April 21, 2009 at 11:38 pm
    The stroke effect should only work on the layer you apply it to. Not sure why its affecting more than that.. Maybe a screenshot would help us understand your particular problem.
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2
    AE CS3
  • Steve Roberts
    April 22, 2009 at 12:31 am
    Have you used adjustment layers? If so, you shouldn’t. You should apply the stroke effect directly to the layer you want to reveal.
  • Staci Daniel
    April 22, 2009 at 9:32 pm
    THANK YOU to everyone trying to help. I DID figure it out… I don’t know what I did or what was wrong, but I opened my file the next day and whatever mystery problem going on the night before had been solved. I clicked so many boxes trying to fix it myself, I don’t know WHAT fixed it or what IT was. Thanks for listening to my crap!
