Activity › Forums › Adobe After Effects › Animating moving Pool Balls
  • Animating moving Pool Balls
    Posted by I Am the eggman on December 26, 2006 at 9:14 pm
    I’m trying to animate moving pool balls on a pool table rolling to the pockets after a break. Any suggestions? (I’ve tried rendering the spheres in a 3d program, but the files are not compatible with After Effects) Could I render an image in Illustrator and apply lighting effects?
    Alexander Gao replied 19 years, 9 months ago 2 Members · 1 Reply
  • Alexander Gao
    December 27, 2006 at 3:29 am
    If you have a 3D program, all you need to do is render the frames to an image sequence (e.g.: .tif sequence) and then import that image sequence in After Effects the same way you would import video. You are better off animating the balls in your 3D program rather than trying to do something in After Effects. It will be much faster and easier.
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
