Activity Forums Apple Motion Animating Masks
  • Animating Masks
    Posted by Phil Muri on June 2, 2007 at 5:21 pm
    Howdy Cowpokes,
    The only way I have been able to animate a mask over time is to hit ‘A’ (record animation button) and change the mask shape at a different place on the timeline.
    While this works fine, I am curious what property (if any) in the Inspector is being animated? Or is it the case that mask animations simply do not animate via the inspector?
    -Phil
    Doyle Rockwell replied 19 years, 3 months ago 2 Members · 1 Reply
  • Doyle Rockwell
    June 2, 2007 at 8:10 pm
    Heya,
    In Motion 3, there’s a parameter called Control Points in the Inspector that acts as the keyframeable parameter for shapes. In the Keyframe Editor, though, it’s displayed as Shape Animation (kinda inconsistent).
    In Motion 1/2, I don’t believe there was a parameter in the Inspector that represented the overall shape. There was one in the Keyframe Editor, though. And you should be able to use the Ctrl+K keyboard shortcut to speed up the work (sets a key on the current frame for the last-adjusted parameter).
