Activity Forums Adobe After Effects animating logo question
  • John Cuevas
    March 6, 2015 at 2:41 am
    Most likely you are going to have to create a mask path for each growing vine/branch/root. Be happy it doesn’t have leaves, I had to do a tree with leaves once. If you use the Generate>Write-On you can keyframe the thickness of the stroke, which will be very handy in a project like this. I would create a mask for a branch, copy the mask path, apply the “Write-on” effect, twirl down the write-on effect, click/highlight “Brush Position” and paste the path. The animate the thickness as needed.
    Here’s a tutorial explaining a few different techniques for doing the effect. https://www.youtube.com/watch?v=V2DS2bfxJ0M
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    March 6, 2015 at 2:42 am
    Another tutorial on the write-on effect.
    https://www.youtube.com/watch?v=9c97vXvDYBQ
    Thinkck.com
