Activity Forums Adobe After Effects Animating layers differently with 2 cameras
  • Animating layers differently with 2 cameras
    Posted by David Vandevelde on May 13, 2013 at 3:35 pm
    I’ve got a composition with a dozen layers, on top of the layers, I’ve added a camera to animate the scene, however I would like to animate the background layer differently to simulate a kind of parallax effect, the problem is that the top camera layer animates the whole scene. I don’t know how to exclude the animation from this background layer or apply a second camera to only animate this one…
    Thanks in advance for your help!
    David
    David Vandevelde replied 13 years, 4 months ago 2 Members · 4 Replies
  • Walter Soyka
    May 13, 2013 at 4:21 pm
    If you push your background back in Z-space (and scale it up to fit the frame again if necessary), you will get parallax for free from the single camera.
    Walter Soyka
  • David Vandevelde
    May 13, 2013 at 4:46 pm
    Yes that’s a great trick but my camera is rotated around in the Y axis and I would like this background layer not being rotated as the rest of the layers…
  • Walter Soyka
    May 13, 2013 at 5:02 pm
    [david vandevelde] “Yes that’s a great trick but my camera is rotated around in the Y axis and I would like this background layer not being rotated as the rest of the layers…”
    You can’t have two cameras rendering simultaneously in the same comp. A few other options:
    Make the background 2D and animate its transforms.
    Keep the background 3D (if you want DoF, for example), parent it to the camera, animate its transforms.
    Precompose the background, add a separate camera in the precomp and animate there, leave collapse transformations off for the precomp layer.
    Walter Soyka
  • David Vandevelde
    May 13, 2013 at 5:05 pm
    thx, I’ll try these solutions!
