Activity › Forums › Adobe Photoshop › animating keyframes in photoshop cc – timeline panel
  • animating keyframes in photoshop cc – timeline panel
    Posted by Esther Casas on September 10, 2018 at 9:29 pm
    Hello everyone!
    I have to animate few assets in photoshop (i normally do it in AE but for this specific project I have to do it on PSDs as I get them form other people). I have never done it and I thought it was easier to navigate. I am stuck with the simple action of not knowing how to create keyframes for example in the “POSITION” option in a video layer and animate that position with keyframes, as I do in AE all teh time, how the hell I edit values here?. Also, is there a way to make ALL the videolayers shorter or longer at once instead of having to drag each individual layer at a time? I don’t find teh option to change teh duration of ALL in one click, it take s along time to do each single one when you have many. Could you pls help? this seems obvious but I can’t find the way to do these 2 things in photoshop! Here a pic of one of my problems…for example here I like to start keyframes in position like is done in TRAIN videolayer (in video layer, not rasterize one, i know you can’t do that into object) also, how do I make all of these layers shorter at once?
    Thank you!!!
    Kalleheikki Kannisto replied 8 years ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    September 11, 2018 at 3:21 pm
    Position values are set by moving the layer and adding a position keyframe. Opacity values by changing the opacity and adding an opacity keyframe. Fiddly as …. .
    Don’t think there’s a way to trim multiple layers at once. At least I haven’t found one.
    Senior Graphic Designer
