Activity › Forums › Apple Final Cut Pro Legacy › ANIMATING KEY FRAMES – Ease in / Ease out
  • ANIMATING KEY FRAMES – Ease in / Ease out
    Posted by Damon Hoydysh on June 4, 2005 at 4:46 pm
    I’m animating still pictures – Ken Burns style pans, zooms, and pull outs. My problem is that when ever I do a zoom out, the picture starts off slow, and then speeds up to complete the zoom at the end of the allotted time for the zoom. I have contol clicked the starting keyframe, and the ending keyframe, and tried the ease in/ease out, but every time I do that, I get a curved path. When I check linear, it still doesn’t work. Anytime I use the ease in / ease out, it completely screws up my animation, giving it new paths and such.
    Anyone know how to make a fade or zoom consistent over the entire allotted time? Furthermore, can anyone tell me how to use ease in / ease out successfully?
    So frustrated.
    Thanks in advance to anyone that can help,
    Damon
    Kevin Monahan replied 21 years, 3 months ago 3 Members · 4 Replies
  • Kevin Monahan
    June 4, 2005 at 6:17 pm
    Damon,
    Get to know the velocity handles on the bezier handles. You can tweak them for more adjustment with your acceleration. My technique involves zooming way in on the Canvas and tweaking the velocity while my comp loops in to out in the QuickView Window.
    It takes a little practice, but you can do it–
    Fore more info on this technique, you may want to check out my book.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Damon Hoydysh
    June 4, 2005 at 8:10 pm
    How can I adjust the velocity without affecting the motion path???
    Damon
  • Arnie Schlissel
    June 4, 2005 at 8:25 pm
    If you have Motion, you might want to do your rostrum moves there. Last month I tried a slide show in Motion just as an experiment, & I immediately decided that I’ll never do another one in FCP as long as I have Motion available to me. It’s waaaayyy faster for me, & I feel like I have much more control.
    Arnie
    https://www.arniepix.com
  • Kevin Monahan
    June 4, 2005 at 8:41 pm
    Of course, Arnie is right. Motion is really good for this job once you get the workflow down.
    To answer your question, the velocity “handle” is really only a small purple dot that is located directly on the bezier handle. You slide it up or down to accelerate or ease. It’s very sensitive, but if you zoom way in on the Canvas, you’ll gain more control. Looping in QuickView (which no one probably does), will allow you to see the result of your tweaks. If you’ve never seen it demo’d, you’d never really even know this thing exists. Unless, of course, you read the manual. But who does that? 😉
    So, you see–it takes extra care to finesse the motion controls in FCP, but it can be done satisfactorily. Especially if you extend the Center keyframes beyond the trim points of the clips, then dissolve through the move. Whether you want to spend that time to do is properly is up to you.
    However, as Arnie points out, Motion is the app to use for full control of position and scale. After Effects can take is one step further with the addition of a simulated 3D environment with 3D cameras and 3D lights. Boris RED which plugs into FCP does a bang up job along these lines as well, but you can extrude the edges of the photos for an added effect very easily.
    Lately, these kinds of projects are so commonplace that I am getting sorta lazy with requests to do this kinda thing for family and friends. For that, I just toss my photos into iPhoto 5 and it actually does the rostrum moves to music automatically. It’s pretty cool. iMovie is also a no brainer way to get the job done down and dirty. The down side is no real control over position, scale or anchor point.
    Good Luck
    Kevin Monahan
    fcpworld.com
