Activity Forums Adobe After Effects Animating Illustrator elements
  • Animating Illustrator elements
    Posted by Katie Montgomery on December 11, 2008 at 7:53 pm
    Hey there
    Newbie q:
    I have an Illustrator file with a pattern of clouds and I would like to animate these clouds separately in 3D space in AE; do I need to first create separate image files in Illustrator (e.g. background, middle ground, foreground) to then bring into AE to animate? or is there a way to keyframe/mask in AE? What is the best workflow for this?
    Solie Swan replied 17 years, 8 months ago 2 Members · 2 Replies
  • Katie Montgomery
    December 12, 2008 at 3:57 pm
    Thanks, Dave! I ended up slicing the clouds in Illustrator and it created a bunch of separate clouds for me that I was able to import into AE with the transparency. Now I have to animate each one separately which I feel may end up being a blessing and a curse.
  • Solie Swan
    December 13, 2008 at 8:07 pm
    You could also crate basic clouds on a solid layer in AE with the pen tool. You might also be able to use expressions to animate your clouds.
