Activity Forums Adobe After Effects Animating Graphic Images in a Circle
  • Animating Graphic Images in a Circle
    Posted by Chip Hess on March 21, 2016 at 4:24 pm
    I have some PNG images I need to arrange around a circle, then rotate the circle of objects.
    I have been creating a circle mask/path using the ellipse tool. But getting the objects to snap to that circular path is the rub.
    The tutorials I have found online seem to all use the pen tool to draw a path freeform. I need a perfect circle.
    What is the best/easiest way to do this, thanks!
    Chip Hess replied 10 years, 5 months ago 2 Members · 5 Replies
  • John Cuevas
    March 23, 2016 at 2:21 pm
    Hold down shift for a perfect circle, add cntl after you start making your circle to have it anchor to where you started making your circle.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chip Hess
    March 25, 2016 at 10:14 pm
    Thanks.
    So here is what I am seeing.
    I draw the mask/path, perfect circle.
    Copy mask path, paste it onto position
    of the image I need to align.
    When I do that, another path with handles
    gets created, and the image follows THAT path.
    I suppose I could live with that, but how to move
    or resize that path with the handles?
  • Chip Hess
    March 27, 2016 at 10:21 pm
    Thanks so much guys, everything is working now 🙂
  • Chip Hess
    March 31, 2016 at 1:52 pm
    One more obvious question –
    Other than eyeballing it, is there a more precise way
    to align the objects around the circle, so they are
    exactly spaced apart?
  • Chip Hess
    March 31, 2016 at 6:35 pm
    Dave, does the referenced null technique automatically space all images equally distant from each one’s center? So they are distributed equally around the circle?
    That wasn’t my understanding – hence the question.
    Thanks.
