Activity Forums Adobe After Effects Animating geometric swirling lines
  • Animating geometric swirling lines
    Posted by Nathan Halder on October 11, 2012 at 1:29 am
    I’m having trouble trying to describe, and therefore search the internet and forum for creating and animating lines like this:
    I have the Trapcode Suite, so I was playing around with Stroke. I also tried to make a grid and keyframe Bezier warp but I’m not really getting what I want.
    What I would like to create are these types of lines that are animated with a gentle wave type motion.
    Any suggestions?
    John Cuevas replied 13 years, 10 months ago 3 Members · 5 Replies
  • Vishesh Arora
    October 11, 2012 at 6:11 am
    Nathan
    Have a look at this tutorial:
    https://ae.tutsplus.com/tutorials/motion-graphics/how-to-create-glowing-elegant-lines/
    This is not the one you want but may help you to get the result you want.
    Vishesh Arora
    VFX and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Vishesh Arora
    October 11, 2012 at 6:37 am
    Nathan
    Try this:
    1. Apply 3D stroke to a solid.
    2. Make a path using pen tool(Try to use 3 or 4 four vertices) .
    3. Go to Repeater, Enable it and then change settings as Required.
    4. Animate the mask Path and all stroke will follow the same movement.
    Vishesh Arora
    Films Rajendra
    Blog:
    Demo Reel(3D):
  • John Cuevas
    October 11, 2012 at 12:21 pm
    Trapcode Stroke is the right path. Create a solid and make a smooth curvy mask. Apply stroke. In my example project I made the thickness 1.8, Feather 100, Enabled “Taper” and under the “Advanced” tab turned down the internal opacity to 40%.
    The real magic occurs in the repeater tab. I turned up my instances to 8, play with the X & Y rotation and Z displacement for the initial look. Then start playing “Scale” and “Factor” and you should have something very similar.
    Here’s the project I created: 4782_wavystrokelines.aep.zip
    Hope that gets you on the right path(no pun intended)
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Nathan Halder
    October 11, 2012 at 10:31 pm
    Thank you Vishesh and John.
    John, your comp was more what I was looking for. Thanks for the starting point – It looks really good. It’s always cool to look at other people’s work!
  • John Cuevas
    November 11, 2012 at 3:43 am
    Glad I could help.
    Thinkck.com
