Activity Forums Adobe After Effects Animating gas particles in After Effects
  • Animating gas particles in After Effects
    Posted by Justin Maloney on June 25, 2020 at 4:27 pm
    I’m working on Science education material and we’re doing ALOT of animations of gas particles. The basic parameters are such.
    -Each particle moves in a STRAIGHT line.
    -Particles bounce off the edges of their container.
    -Particles bounce when colliding with one another.
    I’m trying to create something with Trapcode Form or Particular but I can’t get the particles to respect these parameters and the scientists are complaining that its not accurate enough.
    Here is a gif they gave me that (sort of) illustrates what they want. Gas particles are on the right.
    https://i.gifer.com/9YCx.gif
    The big difference between the animations I’m working on and this example is that the vessel the particles are in have to expand and contract, slowing down and speeding up the particles inside while doing so.
    Obviously doing that manually is a nightmare. I’m hoping some kind of particle system can get the job done.
    Any ideas?
    Filip Vandueren replied 6 years, 2 months ago 4 Members · 3 Replies
  • Richard Garabedain
    June 25, 2020 at 10:47 pm
    if you had Newton it would be pretty easy…that being said…cc ball action is almost close…but…if you have a solid with several small balls and then you use radio waves on a new solid that references this one.. and you add spin and reflection..you can get hollow spheres to do exactly like your animation…too bad other effects cannot use this reflection ability
  • Graham Quince
    June 28, 2020 at 8:59 pm
    Years ago I used Particle Playground’s wall settings to help explain Charles’ Law:
    https://youtu.be/bWhs5L_gBTI
    PP won’t get you particles interacting with each other, but will get the container interactions.
    http://www.YouTube.com/ShiveringCactus – After Effects Tutorials
  • Filip Vandueren
    June 29, 2020 at 2:39 pm
    I think it’s a lot to ask of a particle system in a 2D animation app.
    For a simple 2D look, maybe this is something that is better coded in something like Processing?
    Or in 3D Blender with something like the “molecular” addon script ?
