Activity › Forums › Adobe After Effects › Animating Footage within an Animated Mask
  • Animating Footage within an Animated Mask
    Posted by Jim Zito on September 20, 2005 at 6:35 pm
    I have footage that animates on using an animated mask. While the footage is on screen, I want to animate it WITHIN the mask. I know you’re supposed to use the pan behind tool, but when I do, it creates another keyframe for the mask and the mask itself moves too. I tried creating a second mask and just using that to animate the footage, but it still creates a new keyframe for the first mask even when I lock it. Is there asimple way to do this and maybe I’m missing it? Thanks.
    Jim
    Jim Zito replied 21 years ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    September 21, 2005 at 2:46 am
    Break down the workflow into two comps. In the first comp, perform your pan/movement on the layer. Then nest that into another comp. Now draw your mask and all should be fine. Another method is to use the Stencil and a single comp. Do your pans and then create a stencil layer on top of the panned layer. Lots of other ways but these should work well for you.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Jim Zito
    September 21, 2005 at 2:44 pm
    Thanks Roland. Yeah, I guess I should’ve thought outside the box. I just wanted a simpler way of doing it all in one comp I guess. Thanks again,
    Jim
