Activity Forums Adobe After Effects Animating “expanded technical drawings”.
  • Animating “expanded technical drawings”.
    Posted by Jack Kelly on November 11, 2005 at 3:24 pm
    I’d like to do the following shot in AE:
    1) Start with an expanded drawing of a motor bike, a little like this one of a lathe:
    2) animate this so the components move together to form a fully-built bike.
    3) Transition to a real, photographic, static image of a bike
    4) Add a real rider
    5) Transition to moving image of the rider riding the bike off frame (both the bike and the rider will be real, not CGI)
    Will this all be possible with AE and Illustrator? I’ve played with importing PSDs into AE and making them into “2.5d” animations… but is it easy to import designs from Illustrator and make these “2.5d”? Will is be possible to create the “expanded technical drawing” in Illustrator and then to import this into AE for animation? I understand that AE can’t do truley 3D objects but am I right in assuming that I can mock up this shot by placing 2d objects from Illustrator in 3D space?
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Jack Kelly replied 20 years, 9 months ago 3 Members · 3 Replies
  • Erik Lindahl
    November 11, 2005 at 11:49 pm
    I’d opt for working in 3D first as well
  • Mike Smith
    November 12, 2005 at 11:03 am
    Though you could make it work in AE. You’d want a neat, attractive drawing – ditch all those explanatory labelling lines? – and you’d want to take care the lines weren’t so thin (1 pixlel, no blur) that they flicker on alternate fields on video out.
    Then you’d want to separate out the drawing elements onto different layers, mask around the shapes, and animate the layers together … as an alternative to a straight mix to bring on the photo image (which you’ve pre-checked aligns with the drawing, right?) you could experiment with custom gradient wipes or other transitions.
    So long as you keep it short and the expanded drawing lines up properly when brought together with your photo, it should make an adequate little trick ..
  • Jack Kelly
    November 12, 2005 at 12:31 pm
    Hi guys,
    Thanks a lot for your help. Hmmm… maybe this will be my best excuse yet for learning a 3D app!
    I’ll have a tinker and let you know how I get on.
    Thanks a lot,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
