Animating equalizer
I am trying to create an animated equalizer, with a specific look. Here is the static design of what needs to be animated.
In my attempts, I am able to create this. Here I have used Sound Keys??? spectrum and colormap as the base graphics. The colormap has been quantized, and used a Simple Choker for the rounded corners. However, I would like to use one of the rounded corner pills from the static image from above, and not the choked colormap.
How do I go about so I can have the pill (from the static graphic) represent a quantized sections in the animated equalizer? Thanks in advance.
